group 27f deep cycle battery
Tierra y Libertad
I searched...and did not find what I am looking for.
Besides an Optima Blue Top, is there a straight swap deep cycle battery out there in a reversed post set up like the group 27F...That is a negative for Costco's Kirkland series and pretty much everything else I am seeing... (4 wheel parts does have it for around $140...)
Anything for around $80-$100? Deep Cycle...
thanks...I don't want to give myself another task of extending battery cables....
Try Interstate or SEARS. SEARS' new line, forget the name, are supposed to be high quality new tech with a very long warranty, but the price is something above $150, but they haven't been out long enough for a good long term real world test.
I did get the Costco one.
The cable extension was trivial.
Check an earlier thread.
Call me ignorant, but how are people extending the cables. I removing a few of the zip ties, but still couldn't get the cable to reach to the front of the battery. i have a year old optima in my 93 that I want to swap to the 97, but after looking closer, it looks like the 93 has had the cables spliced and extended. Does someone make some bolt on extensions?
The new Sears Die Hard Platinum line's closest battery for the LC is a group 34. For $190 it still only has 100 minutes of reserve, not great for that much money. The correct group 24f Die Hard International is $120 and has 150 minutes of reserve, which is near that of a deep cycle. Given it's not a deep cycle and it probably can't take fully deep cycling it's a great choice. Otherwise there is no direct deep cycle fit in the LC, unless you go with a ~$300 Odyssey battery.
If you're paying ca $300.00 for an Odyssey then you're paying too much....
Odyssey's are simply the best available, period....
Reserve capacity has nothing to do with defining a battery as deep cycle or not.
Fred
Fred
If I'm not mistaken, the going price on the Odyssey that fits is about $250-$300 is it not??
Reserve capacity is what you're after when looking for a battery to be used in a deep cycle application. However, a deep cycle battery will greatly outlast a typical battery when it is reguarly cycled.
Just a thought but couldn't you take any of the Optima deep cycles with GM side-posts (D34/78), and lay it on its back? That would cause the "side posts" to become the top posts, and they would be oriented correctly for the 80.
Almost any of the Odyssey's will fit.
They also make them in left and right post configurations.
Again, reserve capacity has nothing to do if a battery is a deep cycle or not.
Deep cycle batteries come in a lot of different reserve capacities.
A deep cycle battery is one that can be, successfully, and multiple times, be discharged more than 3% or so and not suffer damage.
They can be deeply discharged and then recharged without hurting the battery and they can withstand that a lot of times.
A non deep cycle battery, regardless of it's reserve capacity (which is really nothing more than a function of it's size) can not handle deep discharges without damage to the battery, usually in the form of calcium deposits on the plates.
Again, the Odssey is simply the best, by far, of any of the retail commercially available batteries.
Out here in souther Arizona, Optima's seldom last 2 years for most people, many, that I know first hand (including myself) don't/didn't even get that length of time from them.
They aren't a "dry cell" type battery. They are a AGM type (as are the Odyssey's), however they aren't a 100% absorbed acid battery and they do have evaporation lose which is what causes them to die, at least in hot climates, in about the same length of time as normal non sealed lead/acid type batteries.
Fred
Try hooking a wench up to those side post and see what happens ;)
Fred
That's cool to know. From what I had read, I got the jist that reserve cap. was somthing to judged between batteries. I knew they were made different to survive the cycling, but I guess it makes sense that a deep cycle is better suited regardless of it's reserve due to this.
Fred
Unfortunately for the Optima´s fate, what you say is absolutely true.
Following the hype of the Optimas, I imported several yellow top, to resell here and none of them (with the notable exception of one still on my Cruiser), has lasted two years.
A year later, another company imported many thousand for wholesale and ended out bussiness, thanks to the dead ones returned during the warranty period plus the ones unsold that got damaged by themself.:frown:
The only other deep cycle brand available here were Delco Voyagers, which last about 3 years (I am not too happy with them,) , so I will try to replace my two main Delco´s with the Odissey´s.
Seems that it should be a better investement to set a solar panel on top of my cruiser instead all the gasoline charging and all money I wasted in replacing every two years one after one of my deep cycle batteries, to power my 12V Freezer/Refrigerator, when I camped for several days in the same place. And I was the only one in our group who were monitoring all the time the batteries and relaying the load to the other, once their voltage dropped to 10,5 volt.
Here we go again....Nothing is trivial for me...as my wrenching projects always take longer than I expect....:banana::wrench: will search again for battery cable extensions now...
Fred
Hooking a wench up to a battery is more of a weekend thing for me. :D
dude, you go to a welding store, buy a $5 piece of welding cable, have them put on a couple of $2 connectors, tie the extension to your existing ground cable with a bolt and you're done....
