Ground Locations EC and BM
Louisville
Can anyone tell me where ground EC (Right rear bank of cylinder head) is located. I have looked back there and don't see it. Also ground BM (left rear side quarter panel). This is on a 1999. I am looking at the Electrical Wiring Diagram but I am not very good at reading it yet.
I know I have a bad ground to the fuel pump because there is a jumper ground that fixed the problem. I feel that this could be the same issue that is causing the odometer, speedometer, and tachometer to be bad. I am trying to trace wires to see.
Looks like BM is inside the left rear jack compartment.
EC is exactly as described, rear of right valve cover area.
Both fuel pump wires go to the Fuel Pump Control ECU. The ECU gets power via the EFI fuse & relay and grounds at BM.
I found the grounds and checked them. Both look good. I did come across this while following the ground from the fuel pump (black wire red stripe)
Pretty sure Toyota did not do this.
Here is the jumper for reference
