grinding noise help
Golden Colorado
This happens only sometimes, not effected by engine RPMs only speed of truck. Has happened more after running about 20 minutes or so. Not effected by turning, sounds like coming from around the t case. When the truck is turned off I can coast it down a hill slowly and walk besides the rig and can hear it, when I pull in the park brake a little it will change or even go away. Happened once very loud and I parked for about two hours then drove 30 miles with nothing at all.
Some times it will make this noise if I start out and just barely give the truck gas (real light on the throttle) it will start then has gone away
Seems to always go away when I park for a while
Will make noise in 2 wheel and 4 wheel lo (havn't tried hi)
Im thinking it has someting to do with the P brake or even the t case???
Help please I have done searches but my description is different
Thanks in advance for your help!
could be t case related, try taking your handbrake drum off and seeing if any little clips or the brake lining has come off and is floating around in there.
my noist that was similar to this was actually bits of starter motor floating around in the bellhousing
