Is the green wire modification needed IF the FUEL CUT/DECEL VACUUM SWITCH is connected to the appropriate port on the carb (fuel cut port)?
Oh, that green wire mod...
The decel vacuum switch operates under certain parameters of engine vacuum and speed with a signal from the emissions computer, to close the ICS and lean out the mix on deacceleration, I imagine for emissions.
If you ground the WHITE wire (that why the 'green-wire' confusion) you by-pass the emission computer rendering the decel Vacuum switch inoperative because the ICS will always be on (open) as long as the ignition key is in the 'Run' position, energizing the ICS.
Uh, what?
Do I want the the decel vacuum switch to be in-op? And do I want the ICS always to be on? IOW do I want to round the white wire coming out of the green thing if I'm de-smogging?
(Holy Crap this stuff is complicated and annoying! What were they thinking??)
Uh, what?
If your trucks idles just fine now, you don't have to bypass the emission "computer" control of the fuel cut solenoid as part of a de-smog, you can just leave the decel vacuum switch intact. The trouble a lot of folks have though, is that the emission "computer" (really just a printed circuit board with a few components on it) is cold-soldered by the factory and the soldered connection between the wiring harness plug and the circuit board typically cracks and makes an open circuit, where the FCS can't be grounded so that it opens and allows fuel into the idle circuit of the carb. When this happens, your truck will not idle at all without the choke open. To make matters even worse, it usually happens intermittently at first.
The solution to this problem is to either heat and re-flow the solder where the connector joins the circuit board on the emission computer, or to just bypass the emission computer by grounding the white wire from the FCS so that the FCS is always open when the ignition is on. The second option is by far the easiest and it works just fine. My 40 has been running that way for years and a ton of miles.
If you ground the white ICS wire your decel vac switch system will be in-op. You want the ICS to be on when the engine is running or truck won't idle because the idle circuit in the carb will be closed if the ICS were off. Search for ICS, this has been discussed many many many many times.
While I've got you, not to hijack the thread or anything, how do I remove all the HAC stuff and make the HAC constant on? I live at 7k' in the San Juans of CO and she's never gonna go much lower.
Thanks
No such thing as ""Green wire mod". It's the white wire that is cut and grounded. I'd leave the HAC stuff on and make sure it's functioning. But if you want to remove it and make sure the next guy who owns your truck curses your lineage, follow the desmog thread in the FAQ.
