Greasing spindle roller bearings
Due to some nasty and no longer ignorable wheel bearing racket I ordered a set of spindles and wheel bearings from Dan. The roller bearings are not removable to pack with grease so what is the proper procedure? Wheel bearing grease and just push in as much as you can with your finger from the inside?
Thanks, Greg
The roller bearings are not removable to pack with grease so what is the proper procedure? Thanks, Greg
Roller bearings, roller bearings? I thought the spindles had brass bushings.
:cool:
