greasing knuckles
There is a pipe plug on the front top part of the knuckle, remove it, and give it about 20 or so pumps of MOLY (at least) if you have not done this.....ever... ;)
(there is not a zerk)
Back to burning metal.... :D
Good luck!
-Steve
teapot said:
sounds like you should tear it apart and have a go through.
I've had cruisers since '90 & have never pulled that plug on any of them. How do you know if your outer axle seal is gone & is leaking 90 wt. in your knuckles?You need to learn how to tear it apart & reassemble when your birfield breaks. Get yourself a manual & do it right so you have a better piece of mind knowing everything in there is working as it should.
This is pretty obvious when it is occuring....
Further, with a part time system, it really is more of a nuisance with the oil leaking out the back of the wipers when the inner axle seal is leaking, unless it is neglected for an extended period of time, in which case, it can cause issues with your brake pads/shoes....
Good luck!
-Steve
So you can tell this by looking at a mud caked knuckle? Before I started my total rebuild, I tore down the frontend & saw a small puddle of gear oil in there. Even when it was clean I didn't see any leakage around the bottom of the knuckle or even any spots on the driveway.
Good luck!
-Steve
thanks!
it's not as bad as i make it out to be, i put about 20 miles a week on the cruiser and generally keep up with maintenance... thing is i kept greasing everything else and forgetting to ask 'mud how to get into the knuckle. then i would forget until the next time i greased'er up, and now here i am :idea:
