Greasing greasable parts.
Sonoma, CA
Website
www.myspace.com
Instead of paying money to have everything oiled, etc, I'm curious if anyone has a list of all of the moving parts, and what kind of oil/whatever to use on them.
I'm pretty much broke, due to having to buy a plane ticket to Hawaii, and I have to drive almost 1,000 miles in the next 2 weeks.
And I don't want to risk having something seize up or anything awful due to lack of being well lubricated.
Basically, what part of the chassis, drive train, wheels, etc, to grease, and what kind to use.
Mr tomatopants,
I reccomend purchase and review of the factory service manual (FSM)
there are a variety of preventative maintenace tips and procedures contained therein.
Kind regards,
If I weren't currently living out of boxes because I'm moving I would tune and play the worlds smallest violin :crybaby: regarding your need to purchase said plane ticket. hopefully at least it is a seat for yourself?:idea:
I'd put a half tube of grease in both knuckles via the square plug on top, lube the 6 zirc fittings on your two driveshafts (3 ea), check the oil levels in all three differentials, the tranny and the engine oil. Then I'd check the condition and tightness of the 3 engine drive belts, and be sure the coolant and overflow are full. You might also take the air cleaner element out and tap it on the floor to get grit out (be sure to disconnect the large rubber tube BEFORE removing the air cleaner lid - do NOT simply yank up on it to get the element out).
As soon as you're over your financial squeeze I'd call Cdan and order a manual set.
DougM
DougM
I'm still n00b to the max, so I've no idea where the knuckles I have to put half a tube of grease in are.... If you could direct me to those, I'd much appreciate it.
Other than that though, I had my transmission fluid changed and checked out since it was stuck in a high gear after I'd park and then start to drive again so it's perfect, oil's full and on about 1,200 miles, coolants full, and the air filter's a K&N. :cool:
I'm working on getting an OEM. ;p
Thanks for the tips guys.
Read the FAQs and/or search for knuckle diagrams and other references.
DougM
As Doug said, read the FAQs. The link is https://forum.ih8mud.com/showthread.php?t=84888
It is located at the top of the index page for the 80s threads. Start at the top of the FAQs and start reading. Some of it will probably not pretain to you currently, but if you retain some of the info, it will come in handy down the road.
I have been on here for about a year and a half and am about half way through the FAQs...
Riley
This looks like a square bolt in the upper left corner...
The grease you need for the knuckles is a molybdenum disulfide grease. It is called moly grease for easy of pronounciation. Harbor Freight sells it in the tube. You will need a grease gun because the hole you will be feeding it into is only about 3/4" wide.
Just check the ingredients and make sure it contains molybdenum.
Riley
P.S. I was not kidding about reading through the FAQs. Also, please learn and use the search feature. I do not mind helping when I can (my Land Cruiser knowledge is still in the kindergarten phase, but I try), but all of the questions you have asked are out there for the finding.
