grease or oil
alright, i've been working on a spring over on my 1976 FJ40 and I have a question about thr front axle. Do you grease the front knuckles or fill them with oil? I have heard you fill em with oil from my college auto teacher and I've heard grease them from a local cruiser guy up here. The inside of the spindle looks like it is designed for oil and the top of the knuckle does have a filler bolt that looks like its designed more for oil then grease. From everything i've seen on the internet, its been grease. What did they come with from the factory, oil or grease. Which should I use?
Grease all the way. However, most folks feel that you don't really get any
effective lubricant into the birfield by squirting grease into the hole covered
by that square plug. You need to pull the birfs out and clean and repack
them with GREASE. If you find oil in that cavity, it means that the seal
has failed and that your differential lube is leaking into the cavity. Not
pretty.
birfields > pack well with MOLY grease
trunion and wheel bearings > pack with wheel bearing grease
front axle housing > fill with 80W-90 gear lube (make sure the inner axle seal is good)
PERSONALLY - because my front axle gets stripped yearly for maintenance, I do not bother filling the cavity with grease....I schmear moly on the spindle, fill the birf, pack the trunions, pack the wheel bearings, and don't add ANY additional....grease will not migrate magically into the bearings anyways.
