Grade mark on bolt?
Gainesville, FL
Hi all,
I recently completed the mini-truck disk brake swap on my 72. With the axles I have Aisin hubs, which have these bolts. I'm missing one of them, is this anything special? I wasn't sure if this "7" is a grade marking or can I use any M6 x 1.00 bolt I have here?
The threads on the hole are beat up so I'm hoping i can tap it and put one in there...I've been driving it with the missing bolt since i finished the swap with no problems but would like to have them all back...
Poser said:
You can use any decent 6 x 1.0 bolt.
:beer:
Oh, no. You MUST go only to the dealer and get the correct bolt. Nothing else could possibly do. Otherwise, how could you call it a land cruiser? It might as well have a 350 in there. People just running around with all kinds of domestic parts on there and misrepresenting their abominations as toyotas is blasphemy and will result in hellfire and damnation.
Thanks for the quick answer.
I have some laying around but for sh!ts and giggles I asked a few guys while out buying various things today...2 folks said they had no idea (at the autoparts store), and 1 guy said its a 'grade 7' marking indicating an extremely hard bolt that needs to have the same type re-installed (in the sears tool dept, where i was getting a tap).
I was skeptical as these bolts don't seem to need much torque etc, but i wanted to verify.
Thanks again.
I found this info at the Bolt Depot:
Bolt Depot - Bolt Grade Markings and Strength Chart
But it doesn't show anything about a class 7 metric bolt. If that 7 is the class designation, then based on what is shown I would guess its equivalent to to a typical grade 2 bolt.
Here's a more detailed reference, but all of the metric classes and markings should have decimal points in them.
bolts: metric standards
The numbers have nothing to do with the new standards that people in shops will recognise.
The Yota bolts were numbered from 4 to 7 depending on the strength and expected final torque.
So for example a 6mm number 4 bolt was torqued to 3-5 ftlb, a number 5 was 5-6 ftlb, a number 6 was also 5-6 and a number 7 was 6-8 ftlb.
Not sure why 5 and 6 are the same, I'm just reading the manual. Different coatings? There seem to be less bolts in the 6 series, with the largest being 12x1.75 pitch vs 16x2 in the 5 series.
Thanks; I went thru my Toyota Chassis/Body manual again last night and I still didn't see it (again I could still be missing it, i didn't read every word in there).
I don't even have a chapter 14, mine ends at Chpt13 (accessories), and I definitely do not have that chart that you posted above so thank you for that!
