gotta question
montreal mo
Website
www.ozarkoffroadfab.com
i bought a 93 blazer with 4.3 4l60 and transfercase
its a drivers drop. anyone ever use a rear axle spun around to the front and cut out the knuckles off the front to make the rear a driver drop front?
was just curious to see if there is a snag to my thinking. theyt all look the same diameters and width.
i think im going to try it unless someone has tried and it wont work.
i drive my 40 daily and im going to spring over it with some 35 or 36's and then wheel the piss out of it and drive it to work.
let me know, post and link, or even pictures if you have them.
if i dont get a response, then in a week or so ill try it and take a ton of pics while doing it.
thanks
Welcome.
Toss the 208 garbage case and gain some rear drive shaft, along with not having to go through the work of building a new front axle....
Way too much screwing around for me for what you will have in the end.....but to each their own.
Good luck!
-Steve
mo_fj40 said:
well its not a 208, and i havent seen anyone else do anythingl ike that.
Then it is a 231/41 and it is still a chain case, and still garbage....
During some of your research, it would be difficult to not notice people replacing garbage chain drive transfer cases with something decent....
Further, if you really think that building a driver side drop front axle is not that big of a deal, and easier than installing a tcase that has the correct front drop, then get after it. Please post up a lot of pictures of this build.
mo_fj40 said:
it really isnt alot of work from my research. besides it will look neat wheni do it. im only running 35s and i dailt drive it.
Hopefully your novelty will be safe....it is not just your life in the mix.
well, if you look at the diameter of the axle tubes front and rear, then look to see how the knuckles are cut when you turn them, then you see it should be easy. as far as the 231/41 transfercase, i know they are chain driven, i know they arent the most desireable, but it is what i already have in this blazer im getting.
as for the novelty, i have been fabricating rock buggies, jeeps, full sized trucks, drag cars and pulling trucks for over 10 years now, so have no fear in my fabbing skills.
now i know your intentions are good, but they are over kill. i have run many jeeps with the 231 an had zero problems. if i were running lets say a 37 inch tire, id upgrade the transfercase. i do not see a need when im only looking for 35's.
in my tube buggy im building i have the rockwells 44 inch tires, and so forth and so forth.
ill take a ton of pics for this one. if it doesnt work, ill throw in a 60 rear and a ford hi pinnion 44 front that i have.
