Got some fuel issues - I think
Website
www.autohomeus.com
My FZJ80 has two tanks and parallel fuel systems. When driving on the 'stock system' using all the stock equipment I am getting a faint surging and power goes up and down - not a lot, but noticeable. This does not happen when I am running on the subtank, which has it's own HP electric fuel pump.
I am trying to identify all possible causes before I start to ID the cause of the problem. All help appreciated.
MIKE
The second system needs to have a check valve in it and how are you switching tanks?
Bill
Bill
I assume you mean a check valve to eliminate the possibility of some back flow?
The aux system has a Aussie Long Ranger (44 gallons) plumbed through a common Mallory high capacity fuel filter on the frame rail, then to the electric pump, and into a switching switching solenoid on the DS fender in the engine compartment. When the dash mounted subtank button is pressed, a relay switches the fuel and turns on the electric pump. It also switches the fuel gauge to the sender in the subtank. Both systems, of course, share the injector pump and pressure regulator.
I am replacing the fuel filter in the engine compartment today. I'll see if that makes any difference.
Mike
The stock fuel pump has a check valve built in to it. This keeps the fuel line pressurized so when you start the cruiser fuel does not have to pick up from the tank and come up to pressure. The aux. system has no check valve in it so when you switch tanks under load you will get a hesitation or jerk until the pump pressure catches up. This lack of check valve then means that the switching valve always has pressure from the stock system on one side of the valve spool and no pressure on the other aux. side. Pressure from the stock system can then seep past the o-ring on the spool to the aux. system side causing inadequate pressure and causing the surging. In my case it pushed the o-ring completely off the spool and parts of the o-ring were wedged up in the fuel line. I think if you connect the stock line back up temporarily eliminating the switching valve, the problem will disappear and you will also notice a power increase because the switching valve also causes volume losses.
Bill
THAT is what I was looking for! I assume that you were able to remedy the problem in your truck?
A couple of questions...
1. If I add a check valve to the aux line, should it go between the engine and the switch--- never mind - seems like the check valve should go between the pump and the switch to equalize pressure on both sides... right?
2. What is the normal pressure that should be maintained in the feed line to the injector pump?
3. Got a Toyota part number for the check valve for the FZ-FE?
Thanks,
Mike
Thanks,
Mike
Yes, I was able to remedy the situation and I really like a parallel system instead of a transfer system. I think we kinda had this conservation before but maybe I am misremembering. What I did was make a flange the same as on the stock tank; take the 44 gallon aux. tank down and cut a hole in it just over the baffles. I then welded the flange on and installed a stock pump and sending unit. So two stock duplicate systems. It works wonderful!
1) The check valve should go as close to the tank or inside the tank if possible. As you have deduced if there is 43 psi on one side of the switching spool and 43 psi on the other there is a balance when switching. As a fringe benefit, at least to the way I did it, is if both lines always have constant pressure on them, there is no need for the switching valve on the pressure side. The fuel lines from each tank can just be teed together. When one pump turns on it cannot pump fuel back to the other tank through the pressure line since it has a check valve on it. In the case of the stock pump, the check valve is in the pump itself. So only the returns have to be switched depending on which tank is being pumped from/to.
2) 43 psi is considered normal iirc.
3) That is the problem, locating a check valve. Toyota does not have one since the check valve is built in the fuel pump. I have one of these I got for some other project but I can’t find my Earl’s catalog now to see what the pressure rating is. I did this a long time ago and maybe something else is now available, perhaps in hydraulic fittings? HTH
Bill
<rant>
I had a horrible time on a trip with that system you have. I had installed it and after 10 hours of driving in the heat the pump was howling like a banshee. I contacted the company where I bought it and they wanted the old pump back first???? Meanwhile I still had 4000 miles to go. Then they would not ship a replacement to Alaska, only to my home address. I had to buy 3 same $$$ pumps along the way, had the problem with the o-ring where I had to have one full tank all the time so the gas could overflow into the other tank so I could run. Then the pump locked up and blew the EFI fuse which left me dead. I had to be towed through customs by a friend (try that sometime – where are you going in our country? Wherever the he** the guy you just asked on the other end on this chain is going)
I called up Mallory and the engineer there told me the pump puts out the correct pressure for the cruiser but it puts out too much volume so on long runs can get hot and lock up. So forgive me if I am still upset with that system and the company that sold it to me. </rant>
Bill
I have not experienced the problems that you have. But I did experience some malfunction of the fuel pump on a recent trip to Southern AZ. Fortunately, I run off the aux tank until I get a low fuel light, then switch to the front (OEM) tank. The aux pump seems to be working fine right now, but it is NOT the Mallory pump that came with the kit. It is wrapped in rubberized foam, so I will wait to investigate specs until I start in with the check valve install.
I crawled under and looked at the aux fuel pump - it is mounted on the DS frame rail right after the Mallory 3160 filter. I am trying to locate a metal 3/8" barbed check valve . Here are the items I found on Summit Racing's site (local sources appear to be unable to supply one. I may have to use one of the Earl's valves and screw some barb fittings onto the AN male fitting, then strap it to the side rail ahead of the pump. Probably going to need a mini skid plate to protect all the fuel components on the frame rail, too. ;-)
Check Valves, Fluid - summitracing.com
I will also install a WIX replacement for the stock fuel filter. After all this I hope that the continual, low grade issues will be GONE.
Thanks for your great help, Bill!
Mike S
PS: I believe that we had a similar, but less specific, discussion on this last year.
Mike,
After you get the check valve in and running, please check any rubber connections in the system. I ran metal lines back to the aux. tank so just have a little rubber hose on each end like stock. With your set up, the pump and filter may be in the middle with several connections that could potentially leak when held under pressure. If you put the check valve between the pump and the switching valve this will fix the switching valve pressure stuff. There will still be a hesitation when switching tanks under load since the pump will still have to pull fuel from the tank first and get it up to pressure.
About a week ago my brother’s pickup went up in a ball of flames. He took it to some garage :rolleyes: and they adjusted his pressure regulator to 150 psi :eek: and it blew the fuel lines out.
Bill
Thanks. Now I am wondering if the dual inlet fuel filter (Mallory 3160) will allow bleed back o the subtank when running from the aux... Naw, probably not.
Mike
P Man:
Ordered an Earl's Vitron flapper sytle check valve (PN 253006) and 3/'8" hose bibs (PN 700167) from:
AN PLUMBING.COM Earls performance products, Hose ends Hose,Adapters, fittings
I found out that the "AN" numbering specification system stands for "Army Navy"
I have a call and e-mail pending with Mallory tech support. -- edit: the dual in/out mallory 3160 filter has NO return check valves. I'll have to find a check valve with a 3/8" NPT male at the front and 3/8" hose barb at the rear. I would think that the guys at MAF would have figured this all out when they developed the kit!
Thanks for your help.
Mike S
