Got Cruiser? Finally... Yes!
Salem, UTAH
First, thanks to everyone who has helped with info and stupid questions over the past months (trunk monkey and others).
Finally my wait is over... after a year or so cruiser hunting I found one that fit the requirements. Pics will come soon.
'96, emerald (not first or second choice), locked, 147K, single owner, anal record keeper, no body rust, and overall in general good condition. It is a definite mall cruiser. It even has a little surfer girl emblem on the back hatch.
Besides the usual stuff (washer fluid diverter, antenna mast, few dash lights) every things looks great and seems to be in order. The Birfs are the best/cleanest I have seen in 1 year of looking.
I really am having only Two major concern right now about my new toy... Please any help would be great.
First, the PO records show that the both front axles have been replaced at least twice in the last 5 years.
Prior to that the Transfer case was replaced.
Currently the front end feels like it "binds" when slow, sharp turns are made in either direction. Example, pulling into a parking space. sharp turn, slow pull in, then the sensation of having the brakes on while pulling ahead, it won't roll on it's own. It feels weird. From the records the PO had 2 shops look at this (dealer and local) and was told by both that it was normal. Is it normal?
My concern is that it is not normal and something is going on to cause some issues with the front axles...causing the need to replace them more often than they should need to be.
Secondly, is there a way to determine if the clicking during turns is actually from the birfs or from something more sinister and bad.
I am very excited about the cruiser and looking forward starting some little projects with it.
Thanks again, I can now officially use the salute, if my computer wasn't a dinosaur.
The binding you describe....Not normal. No 80 I've driven has ever done that; only big, ugly, lifted Ford/Chevy/Dodges. And most Jeeps.
The clicking is from the birfs. There are no other joints like it in the 80 drivetrain.
As for the TC/axles:
*PO probably had no clue what the CDL button did, so he happily pushed it over and over again, causing stress on the TC/CDL, and breaking it in the process. TC was replaced. He/she was also probably paranoid at the "clicking" sound the birfs made, so they went ahead and replaced the axle as well. Birfs started clicking again, most likely due to being dry, thereby ruining them. Axle gets replaced again.
Just speculation, though.
*Disclaimer: None of the above speculation about the TC/axles is based on actual fact.
Not supercharged, had a pressure gauge for air leveling shocks on the rear (fooled me). It was a real piece upon further inspection.
Thx.
congrats:cheers:...Let's see some pics know.
This sounds like drivetrain binding - either the center differential is not functioning properly (as previously mentioned by toylndcrusr), or is stuck locked. I would actually recommend not driving the truck until you get this investigated - as it could lead to very expensive damage.
One way to test if the issue is the CDL stuck in lock position or not functioning properly would be to take it out to a field with loose dirt and drive in tight circles - you should hear the drivetrain "snap" as one of the tires slips and releases the bind.
-Phil
Just had another thought - try putting the truck in low (don't drive it like this in its current state) - does the CDL light come on on the dash? If it doesn't the CDL could be stuck in lock and the bulb burned out or not functioning.
This would also serve to re-actuate the CDL and then release it, possibly freeing it if the actuator is stuck.
OK...still pics to come.
The CDL seems to be functioning as it should, as far as shifting to low goes, ABS and CDL light come on. I will go drive at lunch and pay particular notice to different feels in low (CDL light on) and just in high.
More to come...
binding drivetrain
Ok went for a nice drive in circles and figure 8's at lunch... the McDonalds crowd thought I was crazy... maybe I am, I bought a cruiser. haha.
I could not feel any difference between high gear (no CDL light) and low gear (CDL and ABS lights on).
In both cases the rear wheel on the inside of the turn would 'skid' a little.
only other differece that I noticed was the if I was turning circles, it took longer for the CDL light to go off, than if I just drove straight and then shifted to high (lights go of immediately)
Am I toast?
Thanks!
