So i have been wanting to mount a tablet in the 80 for some time. I looked at all the mounts available, several home made ideas, and any pics I could find, and I could not find any good mount ideas for the 80. Being that I go pretty remote over rough terrain I was concerned that a single mounting point from the center console (the most obvious mounting location) would still have more flex than I feel comfortable with due to the length of the arm, and I would need to tie into a second location, up high to prevent flex of the arm. The most obvious point to tie into for a secondary mount would be the dash, or behind it. Not wanting to drill into the dash I started exploring behind the clock, which will be blocked by the tablet anyway.
Forward Mount - There is a small metal bar just below and behind the clock, I drilled 2 holes into it that align with 2 drilled and tapped (1/4X28) holes in the bracket. The holes in the bracket are just behind the vertical stand. I used 2 bolts that feed up vertically through the holes in the metal bar and secure it to the bracket I made
Rear Mount - The main dash support, a structural piece, about 8" back made of thick wall tube. I welded the rear of the bracket (with small cutt-out) to this
I fabricated a bracket as you can see in pictures that can easily be made for about $10. Please don't laugh, I didn't clean it up much as it is not visible. The bracket can be SQUEEZED in through the clock hole. It was then bolted to the front cross bar. I tapped the bracket (1/4 X28) where it mounts to the forward bar, as well as the ram mount location. The front bar is to thin to weld to, and I wanted some degree of removability if needed, the rear mount location can be cut if needed, and the front just doesn't have access to do so. I used 3/16 steel for the bracket to prevent flex. The back has to be angled down a little, and is welded to the main dash cross-member.
I bought a RAM ball mount and arm from amazon for about $25 total, and a tablet mount designed for cases, I will post links for them as well. The entire setup is mounted from just this location and no use of the center console is needed. As you can see I made a very sturdy bracket that should hold the arm with no problems. I am still a little worried about the RAM ball joint moving under heavy bumps. If this occurs I will use SUGURU to make a small stand-off that comes off the dash above the radio and supports the distal end of the arm. This will provide a cantilever effect and surely stop any movement at the ball-joint. I am fairly sure it will not be needed, however the arm is horizontal, so the lever effect will remain to be seen.
Anyway, I could not find any tutorials or even pics of a good 80 tablet mount, so I hope this is a help to someone. As for the tablet I got it used from a guy at work for $60. Its a Samsung Galaxy Tab2. It has built in GPS (main requirement) and a 10.1 screen, also a requirement. I rooted it, and got rid of all the BS. It uses a stock ROM cause there's just no reason not to in this application.
Materials Used:
http://www.amazon.com/gp/product/B002KO5XVU?tag=ihco-20
http://www.amazon.com/gp/product/B0098QTFTO?tag=ihco-20
http://www.amazon.com/gp/product/B000WJA5ZY?tag=ihco-20
http://www.amazon.com/gp/product/B004O8LF26?tag=ihco-20
Updates:
- Torque App - A Bluetooth transmitter transmits real time data from the OBD II, also clears and diagnoses fault codes
- Backcounty Navigator - I have multiple Micro-SD cards, 1 per state. Each card has a state and 3 layers of maps per state, Open Street Map, AccuTerra Single Layer (paid), and US TOPO Imagry. They can all be used offline and use the tablets GPS
- Full Factory Service Manual
Materials Used:
Updates:
- So there was a little flex due to the thin material at the forward mount. I slipped a piece of angle iron over the top of my double DIN radio and it fit snugly just under the metal and supported it well. While looking at securing it I found myself facing some Schedule 40 PVC and had an idea. I cut the PVC to the correct length and wedged it in. Since the the mount is bolted in from the bottom there are two bolt heads. I was able to use two pieces of PVC and get the bolt heads centered on them. The bolt heads will prevent movement and the fit very snug between the radio and the support bar. This ties it in well and movement is eliminated. The PVC should also not create any sound as a bonus
