l laid my ute up for a week, l went out today and after starting it & driving way.. its making a 'dry bearing' noise which stops after 100yds or so. My initial thought was previously & still is, as l depress the clutch the noise stops, so l'm thinking 1 of the 2 clutch bearings are on the way out...l want to change the entire clutch, l just haven't had the time.. To throw another spanner into this query, when l went up the valley and stuck my head out of the door l could hear a noise traverse the entire length of the underside of the truck as l slowly drove along ?. (which is a 1st)..The clutch noise wasn't there...Now l'm thinking that this noise might be the alternator as l've short somewhere which drains the battery..(l'll have to check the amp's on it just in case it needs renewed)..l'm going to fit an isolator switch to get around the shorting issue for now as l'm still waiting on my wiring loom quote...
Lastly, l recently fitted a new diesel pump diaphram and my fuel consumption has gone up...l've since adjusted the revs but nothing else would l be right in thinking l might have to also adjust the mixture screw as there's a distinct smell of diesel coming out the rear pipe even when its warmed up after a few miles..?
