Good $67 remote entry.
Bought a remote entry system kit for the 97 a couple months ago and finally got time to put it in today. Install was easy and I'd have been done in 90 minutes had a quick splice (mine) not been defective. Took me a couple hours to figure that out, but the product was a piece of cake to install.
I put the unit in the driver's door next to the factory door lock controller, and it required only 4 splices and a ground, then I used duct tape to simply hang the new unit on the moisture barrier (plastic film). All the wires you need are in the door. Taped the antenna on the plastic film as well and it has great range.
All I wanted was lock/unlock with a remote, but it will also flash the lights, turn on interior lamps, beep the horn, do drivers unlock only on the first push, etc if you want to screw with more wiring and time and get an optional relay kit.
The unit is the Omega RC-11+ and I paid $57.50 at Parts-Express.com plus $10 shipping. It came with two fairly small and nice looking remotes, which can even be setup to open two different cars.
DougM
Doug, I'm very interested in this mod. As you have it hooked up what functions will this unit perform. I'm looking for a unit that will unlock just the drivers door or all doors. Can this unit perform these two basic functions?
Can you also please describe the install in a little more detail such as what wires to splice into?
Heff,
I'd be glad to detail the install if you're buying the unit. Let me know when you get it and I'll PM the wires. Yes, it will do what you describe as I noted in my post above...;-)
DougM
Doug, i may be very interested also. That's exactly what i've been looking for, a cheapo door lock/unlock and that's it. Sounds like you have found one. I'm nervous to attempt an install because i am stupid when it comes to wiring.
I'm electrically challenged. Now that I've done it I could likely install one of these in about an hour for just the basic functions. If you want the more advanced functions besides JUST lock/unlock you'll need to mount the unit out of the door for access to underdash wiring and need to find the wiring there which I have no clue on. I just want to be clear on that. All I did was mount a box that can trigger the factory locks next to the factory lock relay/brain - easy. But for the advanced functions, you'll be needing to connect to the headlight circuits, horn circuits, cut into the ignition wires, etc.
DougM
So you basically duct taped the unit to the back of the plastic in the door panel, and then tapped into a few wires at the control box on the door handle (where the window and door lock buttons are)?
Exactly. I was going to cut a slit in the plastic film and find a way to hang it in the door. But noted that the spot right next to the 80s power lock brain was simply over an open hole and would easily flex to accomodate the remote brain by flexing when the door panel was replaced over it. A bit of duct tape to hold it against the film (actually, I put a lot on there - no need to have something fall apart, eh?), then the door panel shoves against it quite firmly. This way, it's protected from exterior moisture just like the factory lock brain next to it is.
The wires I tapped into are much easier than getting to the ones at the door handle you referenced, BTW. I tapped into them right at the factory lock brain which is just hanging there with complete access. Cdan sent me a copy of the 97 wiring diagram for the factory lock brain in case it was different from my 93 electrical manual (it wasn't - identical).
DougM
Any reason this install would not also work on a 91? I know the 91 didnt come from the factory with this option. Anyone know of any reason it might not work? Thanks
Should. If you have a factory service manual, count the connections coming off the power lock relay and confirm it's in the driver's door. Betcha it's the same. The device I wired to is the power lock relay and if you have power locks you have this thing.
DougM
Thanks Doug. I will check with the manual tomorrow but sounds like I will be able to do it. Here is the reason I want it. I had remote entry on my previous car so I was always able to open the door for my girlfriend. Now, with the LC it is not the same since my key doesnt open the passenger door. Anyone else on here whipped like that? :confused:
Try getting a key cut by the truck's VIN at a Toyota dealer - might work on the passenger door. Also, I've been happily whipped for 11 years - this remote was for my wife's truck....
DougM
Nelson (and a couple others who've asked),
I have to apologize that I've not responded to a couple inquiries on this product. I'm now having trouble with it. Since I don't have a 97 FSM (have a 93) I've had to depend on the kindness of others to get a couple wiring diagrams to be sure it was not my mistake.
What's going on is the remote does not work 95% of the time when you come back to the car to unlock it. It seems to somehow know if you've walked beyond a certain distance from the car and if so, it won't unlock. If you/the remote sit 20 feet away at a sidewalk cafe and have coffee, it will work when you go back to the car. I don't understand this, so I'm working on it. For now, sit tight and I'll get it squared away but not this weekend as it's Father's Day tomorrow and I'm going for a road ride around the lake with my buds, then might take the family out for a boat ride.
The install is so fast/simple I hope I can discover this is just a glitch.
DougM
Yep, though my remotes are nice looking - rounded and smooth. Must be they haven't updated the picture yet.
My remotes are also round and smooth looking...just bought mine about 2 months ago....eventhough I have yet to figure out (or tried) to install them. :confused:
About the only wires I could find that it should hook to where on the ignition harness and I did not feel comfortable cutting into that.
I couldnt figure out how to hook it up to wires in the door like others have mentioned.
I know this is an old thread but its just what I' m needing...i have a 94 with elctric locks and nothing else and want remote lock...what was the mystery fail? could you share what the wires you tapped into were? there are a million threads on this topic but most meander off into all kinds of other issues... yours went straight at what a lot of folks want...
^^^ @IdahoDoug hasn't been on since Nov '17.
If you click on a person's usertag the mini-profile lets you see that.
You might PM him, some people get email alerts for PM's. HTH.
All the wires you need are behind the driver's kick panel and underside of the steering column.
gummycarbs! thanxs... been trying to find that thread where someone listed that all out... cant remember the right search term !
