I ;m in the process of swapping to rear disk i my 77fj40. I found that rockstomper.com has a master and adapter to fit onto my booster .Question is do I still need the portiining valve for the rear disk,s or does that get eliminated alltogether.
Why do you need a Corvette MC? Are you running stock axles? Why not use
the stock MC? Going to a larger bore MC will result in less pedal pressure.
My FJ40 stopped great when I had stock axles with 4 wheel disk brakes and a LC MC and power booster.
I have used the stock Toyota drum brake and disc brake master cylinder for many a rear and 4 wheel disc brake swaps without issue, as long as the residual pressure valves are removed, if the master was a drum brake, or from the rear circuit on a disc/drum master, which is what should be in your truck, unless someone has messed with it.
You will want an adjustable proportioning vavle in the rear circuit.
Good luck!
-Steve
Steve,
Are these things known to be problematic?
Problematic?
Only if you leave them installed since it will keep fluid pressure against the caliper pistons, making the pads drag on the rotors.
