GM automatic temperature
Does anybody know what the safe operating temperature for a 4l60E would be? I have a remote cooler with its own fan mounted under the body to cool my 40 and am trying to decide wether to wire it to come on when the engine fan does. I would like to run it least as possible because its real noisy!! Does anyone make a transmission fluid temperature switch that would kick on the fan? If not i guess i could install a guage and put the fan on a toggle but that would be kind of a pain to always be looking. thanks!
my 700r4 runs from about 190-205 during normal driving.. and some times 210 while climing up a steep grade in the mountains.. but this is my first auto.. anyone elce??
I have a 4l60 in my 4runner. The gm factory manual says 200-210 is normal operating temp. It could easily go to 230-240 and still be ok.
The "target area" is going to be 200 degrees. If you are anywhere from 180-220 normal driving you're ok. When you're working it 240 or so is ok for short periods. Don't want that to be normal operating temp though.
well i ordered an inline switch from summit. It will go on my cooler line before the cooler. its 180F on 170F off switch. I thought that perhaps the 200 on and 185 off would be better so the fan doesn't run so much but they only offered that kind with a 3/8" NPT fitting and i don't think i could mount that in my tranny. thanks!
