GM Alternator
EAST COAST
I have gone through the tech trivia and read every thread I can find on alternators with no luck. I understand how to wire one in, but how do I get one? I need a 90+ amp GM alternator. What GM vehicles can I get one from that will fit with only minor modification? Any help would be greatly appreciated. It needs to fit a stock 74 FJ40 F engine. :beer:
Look into one from an 84 Camaro; a very common model and near the highest in amps ever for a stock V belt driven unit. Autozone, O'Rileys etc. I run one where my smog pump used to be with minor mods to smog pump bracket. Do you or did you have a smog pump? You may have to modify your stock Alt bracket slightly to run this alt. PS this is the model often built to very high amps (mean green, etc), but stick with the plenty high 95 to 105 amps for reliability. The high high amp models (ambulances, etc) are notorious for going bad.
Thank you for the help. I ended up just having my original reworked into a 70 amp.
Recommendation: get a used working spare off Ebay and carry it with you on the trail. I also carry a starter, coil, dizzy or cap and rotor, belts, hoses etc. Hard to find parts in a pinch and out of town. Solution: carry cheap used spares. Have fun!
