Glow plug relay orientation
Canada
I'm moving things around a bit in my LJ78 to install a 2nd battery. The glow plug relay (The part# is 28610-54280) is mounted horizontally (laying on it's side) with two screws bonding it's frame to the chassis. Can I mount this relay vertically without it being bonded to the frame?
Will it mounted vertically depreciate it's life? I only ask because it is mounted in such a robust manner taking up more room than typical relays do...
I can't answer if it's good or not, but I mounted mine verticly behind my original battery , when I added my second. Been fine for a couple of years now.
However there are two other relays, one for the starter and the other I can't recall. They have drain holes in the bottom, and if they are not installed verticly they can fill up when your playing in deep water.
Joel.
Thanks Joel. Those we're the specifics I was looking for. I ended up custom designing a battery tray from angle iron so I ended up not needing to move the relay. I can post picture if it might give some people ideas for a second battery.
