Glow Plug Light Doesn't Work
Warragul, Victoria, Australia
G'day Guys,
I have a 1986 60 series with the 12ht motor. The glow-plug light on the dash board doesn't come on and then to turn off to signal that the motor is right to turn over (I sort of hold the key in the semi-on position for about 5 seconds or so). I've had the truck for about 12 months and in that time it has never worked.
Any suggestions?
Cheers,
Ben
G'day Guys,
Any suggestions?
Cheers,
Ben
Check the fuse, bulb..........you should hear a "click" if its working anyway
You won't see the light unless it's quite cold out... like hovering around 0C or lower (I don't recall the glow curve for the 12HT based on outside temps) and then it will only be on for maybe a second or so (longer if below 0C).
It it runs fine, don't sweat it. The volt gauge also offers a clue to when the glow screen is in operation. The glow light is really just your indication that it's ready to crank over... not whether the system is glowing or not.
X2. I like to see my light go ON... but I always start the truck after the "click". I don't care about the light for starting the truck.
