Glitch at high speeds
Pharr, Tx
first of all, hello to everyone. Hope I'm posting in right place. I have a 1996 LC 4.5l automatic that I'm having issues with. At 40mph and above, my Cruiser has what I would consider a hiccup. Feels like a ran over a board. I've noticed that depending on speed, let's say 60mph, it occurs every 12 sec. I've replaced, spark plugs, cables, cap and rotor, and distributor. Took it to a mechanic and he thinks torque converters locking up but was unsure. Any help would be appreciated. Thanks
Welcome!
How many miles on your truck?
The transmissions on these are rarely an issue.
More likely is something driveline related such as U-Joints, front axle rebuild, wheel bearings.
Do you have any lift and what size tires are you running?
Have you checked your tire pressures? This can affect drive-line wrap-up and how the viscous coupler in the transfer case is operating.
Many things it could be from your description.
So, you feel this in your steering and suspension? You feel it like it shut off, then turned on?
Any CEL codes?
More description and possible a video please.
Welcome!
Any CEL codes?
220,000miles
No lift
265/75r16
Tire pressure good
Doesn't feel steering related
Could be turning off and on but there's no change in gauges when this happens. Rpm's stay the same.
Feels like a nice solid clunk
Last I remember, codes had something to do with exhaust/ Egr.
I did pinch all vacume lines leading and exiting Egr valve and nothing happens.
I'm guessing computer... Only because it has a pattern. 60mph every 14sec, 65mph every 12 sec etc...the faster I go, the more frequent it happens.
Then there are times it goes away for a bit... But not for long.
Try moving the wire harness at the back of the engine (between the firewall and the valve cover) while at idle to see if it causes anything. these are known to cook the wiring harness due to the EGR. If it's getting crispy, it could be failing and causing shorting intervals.
The codes on these can identify a misfire in an injector (also a known problem with a broken plug on injectors) or a misfire due to spark. Go to an O'Reilly or Autozone and borrow the code reader to see if there are any codes being thrown. Not all codes are indicated on the light. Some are stored in the computer, and only trigger a light when something more important happens. Your is OBD2 which senses more than EGR (OBD1 was less diagnostic and ended in mid-1995)
Check your ground wires at the battery to make sure your body and engine are well grounded (I think there are 6 total between the body, frame, and engine)
Check your fusible likns coming out of the battery box on the positive cable. They are $12-$18 and it would be wise to get a new set (Buy two, install one, keep the second as a back-up). These are also known to give odd electrical problems.
Other than that, I'm low on ideas. How about you @inkpot , @LS1FJ40 , @NLXTACY , @scottryana .....others?
I got nothing. 1996 is too new for my blood. That's one of them fancy schmancy Land Cruisers.
Certainly someone has an idea. I don't know much about driveline clunk. Did I read something about the viscous coupler regarding this? Wasn't it @Tools R Us that figured it out? It was about a year ago or so...
Not sure, perhaps the VSS giving a bum speed signal to the ECM. A number of odd things happened to my rig when the VSS was going south. Speedo went crazy, shift points were off, and the cruise would not work. IIRC the trans also needs a good signal to shift property and lockup.
