Glass Fuel Filter?
Negative. Glass breaks. Plastic on the otehr hand smashes along with metal. plastic replacements travel better than glass too. Just my onpinion though.
I use both a plastic one and a glass one in my 40. I use the glass one b/c I am running a weber carb and dont have a fuel window. I will have to check on the brand.
I've been usidng a glass one for a couple years now and I like the fact that I can check at a glance to see if the filter is dirty or not. As far as breakage goes the glass seems pretty thick.
MR.FJ60 said:
... I like the fact that I can check at a glance to see if the filter is dirty or not.
This is my reason for wanting glass. I have used plastic the past two times I have changed them out and would just like to have a clear view of what is going on in them. I don't do much wheeling, so I am not too worried about breakage.
lowtideride said:
huh, the plastic ones i always got you can see thru them.
Yeah, they are not fully opaque... but they are not exactly clear (at least the Purolator ones I have been getting). I can never tell if the gas is clean or dirty through the white plastic ones.
jhstatts said:
Anyone use glass bowl fuel filters on their 60/62? If so, what brand would you recommend?
When using a glass one just mount it so it can't hit anything when driving and its not hanging from the lines . One of those metal wire straps with the rubber around it used for mounting wires and hoses work well .
I watched a 69 GTO burn to the ground when one of those glass ones broke from poor mounting and broke on the intake :eek:
What Mr. fj60 said, but I also wraped in a bit of foam and zip tied it to the original fuel filter bracket. I can still see the glass to check clarity. Bought it at Kreagen Auto.
I will check for brand
not bowl style, but i run an inline style glass filter on my 40 for the same reasons. it had sat for a long time, so i monitor rust from the tank. also helpful to see if you've actually got fuel flowing.
Do You make your own bio?
