Ghetto Speedie sleeve for e-brake drum.
Northern Colorado
I was working on the cruiser last night putting a transfercase in and filled it with gear oil, and a few minutes later i noticed a leak coming from the e-brake, so i took it apart and sure enough, the drum was grooved, so i jumped on line to check on some speedie-sleeves, i also made some calls, everyone local had to order them and it would be around $30.00. I wasnt to fond about waiting a few days to get a sleeve in so i start digging through the garage trying to see if there was some way to Mac Gyver something up.
Well I found something. The little round mint containers that pop in the middle to open or you squeeze around the edges to close are a perfect fit. So i cut the bottom out and tapped it down to where the groove is it is a tight fit and it takes some time to get it where you need without ruining it, but i filled it back with gear oil and its not leaking. I took it for a ride and parked and still no leaks, the Seal is new so this helps but hey it works.
I just wanted to throw this out for all you cheap A##es (like me) and late night wrenchers as a cheap alternative to a speedie sleeve.
Sounds cool, but I am not sure what you mean by this mint thingie. Gotta pic?
No pics, But you can get them at your local convenience store. Description: A round sheet metal or tin container that has a top on it ,you remove the top by pressing the center (kinda like when you open a juice bottle for the first time, and you pop the safety seal) and to close it you squeeze around the edges and it pops again when the center pushes outward and secures the edges. Hmm i think thats the best i can do withouth a pic. Anyway they sell little mints in them.
Oh, yeah. I think I know what you mean. Yeah.
