Getting seat belts to work??? please help.
New Jersey
Website
www.turkinc.com
I have gotten new crow racing seat belts lap belt and a shoulder harnness. but the problem I'm having is that my FJ40 is a 1967 and there are no seatbelt harness's on the floor to set everything to... DOes any one have an idea for meto make the seat belts work for me?
I have a call into Toyota but nothing yet and it has been over a week. they got back to ask more questions but noth else just yet. I'm using the old seats from the crruiser also. so my other question is will the shoulder restraints work since they will be coming over the seat from the back???
please help
I'm new to this whole thing and just starting to refurbish my cruiser.... thanks
john
John, I have a '72 with crow racing belts and kept my bench seats. For the lap part of the belt I put eye-bolts into some existing holes in the floor directly behind the seats (I think they are the original holes to hold down the stock seatbelt, but I am not sure as mine had none when I bought it). For the shoulder harnesses I had a crossing horizontal bar welded into my rollcage that is almost even with the top of the seat and used a wrapping connection to secure it (I would bolt it if I could think of a safe way to do it). To loosen, it has to fight itself so its pretty effective.
If you don't have a rollcage, I would strongly suggest getting one or getting different seats. It is very dangerous to take the shoulder straps and secure them behind the seat on the floor. In an accident, this will compress the spine and greater speeds effect this force exponentially.
I am really happy with my setup. Hope this helps.
Mike
well john, i'm no pro on the matter, but if these seatbelts are what i think they are. i would suggest that you drill a hole in the tub and anchor your lap belts with a metal backplate on both sides of the seat. And as for the shoulder belts, i see that you have two options, one of which would be to anchor them to the tub a good ways back from the seat, the second option would be to weld a bar in that runs across the tub about half way up the main hoop of your roll bar and then you could mount to that. if these belts resemble the 4pt harness i have in mind that's what i would do. good luck on your project.
