Getting ready to wrench.
I am planing to replace all my belts and hoses, at the same time I do my leaky valve cover gasket. Is there anything els that I should do while Im there?
To remove the Valve Cover, or as the FSM calls it the "Head Cover," you will need to remove the throttle body. Great opportunity to clean up that and the upper intake. You could also replace spark plugs and distributor wires. How about the PCV and related vacuum hoses to the top of the valve cover.... you could remove the fan clutch and upgrade to Blue.
So many options, it really depends on your motivation, dedication, and.... resources ( :doh: I couldn't think of a another "tion" word)
While in there do the Pesky Heater Hose.
Where are you in Socal?
I put in an order for some parts including a valve cover gasket, maybe we can wrench together.
Im in the I.E. by Redlands. thanks for the offer, it would be cool to work on this with someone els.
