Getting an 07.
Is there anything I should look out for? It’s got about 200 thousand on the clock. Thanks in advance
Stress cracks in the inner fender wells in the engine bay.
Some of the early ones got a batch of weaker rear diff ring gears; if it's 200K on it, it's probably either already been replaced or doesn't need replacing.
Look for a small oil leak from the timing cover. Those were covered under warranty at one time.
dirt/dried up hard mud in the frame.. stains on the ceiling from water leaks through the roof rack mounting points.. notorious transmission shudder..
