Getting A/C Fix
San Diego
Here is what happended to my A/C system. About a month ago my A/C was cold and then all of a sudden it started to blow warm air. So I check the little peep hole and saw bubbles and from reading some threads here it indicate that I needed to recharge the syestem with some R134 refrigerant. I did that and the A/C was cold again. Then about a week later I turned on the A/C again, first cold then went warm again. Sweating and frusterated :mad: so I decided to take it to a friend shop to get it look at. The shop found that the dryer was leaking and the hose that was connected to it was bent, so they replace it. After replacing the required parts went back to fill with frion, but the A/C system would not fill up. The mechanic said that there might be a clogg somewhere. Took the truck to another shop to get it tested for compression, mechanic said A/C evaperator is clogg. So this is where I'm at. Will be picking up the truck tomorrow and will report back if that have solved the problem with my A/C. Until then I will sit back and drink some nice COLD:beer:. By the way I have a 94 FZJ80.
Thanks Nick. Let us know how it comes out after the repair.
-B-
Okay, so I got the truck back today and so far so good. The A/C is cold as ever, it seems that my problems was the clogg A/C evaporator valve and the leaking dryer. The machanic added some dye in the system to detect for leaks. I will drive the truck for a week and then take it back to see if there are anymore leaks.
Did you add the initial recharge of 134 to the system? Did it have any stop leak in it? If so, that may have been what clogged up the expansion valve. A back flush with liquid (flush) or nitrogen can sometimes clear out an expansion valve.
The bent line is one of those wtf was toyota thinking putting the dryer there, and why in the world didn't the guy bend it back.
Hope it stays cool!
Yeah, when I first recharge the A/C I've added the 134 with oil and dye. I think that cause the system to clogged. Now that I've drive it for a few days, it seem to be all good.
I've heard that "stop leak" products for radiators can wreak havoc on systems, sometimes doing even more damage than good.
What's the general consensus with the same type "stop leak" additives in the R134 refill cans?
Thanks!
The consensus is that it is not good. You run the risk of ruining (clogging) your expansion valve which is a costly repair or at the very least, time consuming. Orings are cheaper anyway, hose repair can run up to $35-40 bucks if you take it off the car and have someone fix it. Besides that the stop leak is not garuanteed to work, and most a/c shops won't touch the system if you have introduced it to your system.
I'm not going to say that it won't work, but I wouldn't stick it in my system.
But then again, I'm not sure I need it in there anyway. It's 95 degrees here in DFW with 27% humidity, and I'm having to turn the fan on low b/c it's too chilly in my Cruiser.:D
