Truck now has 460,000 km. Have not rebuilt the injectors in a few years. What kind of millage/km should I be getting as the cruiser ages over time?
If the compression is low, are there copper additives to fill in the small groves in the cylinder walls to increase the compression?
What are symptoms of a worn Fuel injector pump?
IT has also been a few years since doing a valve adjustment. Would doing a adjustment increase the fuel economy?
I know doing valve adjustment on a gas engine increased the performance a bit.
Looking for a used fj60 but....I need to consider my engine, what can be done to extend its life other then a full rebuild?
Oil pressure is normal it rides at half way mark some times higher. So, replacing the cylinder liners, pistons, rings possibly the connecting rod shells and having the head checked for cracks and precups? I can do this work with the engine installed but what about cylinder liners? is there a press required to pull it and can it be rented in Vancouver bc?
