Gears High Low
Can someone explain to me the difference between high and low in a fj80 1991? I just purchased one and I am not sure the difference should've asked for more clearance when I bought it. ITS a Beauty!
It's not just the 80 that has the Lo/Hi gear.
The transfer case has different gears for low range, crawling so more power to the wheels (at lower speeds). The engine revs more, but the car does not move too fast or the wheels don't spin too fast so you can move better/easier off road.
Hi gears for normal on road driving.
Think in terms of a normal transmission. The first gear will move the care from standing still, then you need to shift gears to get some speed.
The low gear in the transfer case will further lower the "speed". It is actually the ratio of the engine speed to the movement of the wheels.
https://en.wikipedia.org/wiki/Gear_ratio
And to shift from High to Low or vice versa you need to be in NEUTRAL AND STOPPED!
So an 80 is AWD, so high range and low range only change the transfer gear ratio respectively. You might want to look into unplugging the rear plug on your transfer case also allowing you to run LOW RANGE with the transfer locked or unlocked which is very useful you'll find.
Let's not confuse him now. You are talking about CDL switch and 7-pin mod. That's for way later, when he decides to go off road.
Right now just baby steps.
No a 1991-1992 80 does not require the 7 PIN MOD only unplugging a plug.
Because the 91-93 comes from the factory with the CDL switch! And an alarm clock! :flipoff2:
