Gear won't engage
Beaverton, Oregon
I need help/advice from you guys. I just got my first fj40 recently and as I started working on it, I found out that the clutch won't shift into gear. Everytime I tried to shift, it grinds. I can only put it in gear when the engine's off. A little history, it was leaking from the slave hose below. (it wasn't tight) So I tight them up and it seems to work. Except it grinds a little when going to 1st, but still go. 2nd and 3rd and rev. no problem. but now it grinds again like before and won't shift. :frown:
Any advice is greatly appreciated....
ivan
68 fj40
96 fzj80
Welcome.
Did you add fluid to the clutch master cylinder?
Did you bleed the clutch slave cylinder?
Sounds like you have air in your hydraulic system, or you have junk components...
Good luck!
-Steve
Poser is right about what to check (as always) but also take a look up above your clutch pedal also and see if it looks wet were the rod goes threw the firewall from the pedal to the clutch master cylinder. you could have a leak there too, you may need a new clutch master cylinder? if not then bleed it just like you would if you were doing the brakes to remove any excess air. that should solve your problem. good luck!
Thanks for the advice guys, I will check it again. Right now I'm a little stuck, family moving in. Garage temporarily converted to storage. I will update you guys with my findings.
