Gear shift problem help!
Hi all, having an issue with my 93 80 - basically it’s not shifting gears in high or low, oil is fine, the motor drives and pulls fine but won’t go out of first.
it has also started giving strange reading on the speedo as it is stuck on 30mph.
suspect it’s electrical Rather than mechanical.
any ideas or suggestions would be appriciated.
It’s most likely the solenoids. The easiest way to check is the manual shift test. Disconnect the solenoid wire. It’s on the left side of the transmission. Drive it shifting manually L 2 D. Try that if it works fine it’s your solenoids. It’s pretty common on these 25+ year old transmission.
