Gear shift light out = problem?
West of the Pecos
When I shift my truck into drive, the "D" light on the instrument panel doesn't come on. P, R, N, 3, 2, and 1 all light up, but no D. Is this a problem, or is it just a bulb burned out?
Transmission seems to work okay, but something I never noticed before is that the gear shift will shift back and forth from "D" to "3"and from "D" to "N" -- also from "1" thru "N" (but not the opposite direction) without first depressing the thumb button on the side of the shifter. Is that normal?
Maybe I'm just not very observant.
:confused:
The shift knob is working as designed. As far as the "D" light. It's just a light. Mine still works, but I have read here that it's not worth the effort of replacing it unless you have to get into your instrument cluster for some other reason.
So you can shift the transmission only in ways that won't chew it up, right?
I figured the light was just a 15 yr old bulb burned out, but just wanted to make sure that there wasn't a problem with the transmission itself.
thanks.
Try smacking the top of the dash, right above the stack of lights/bulbs where the "D" light is.
No, not a joke...Just do a search on the subject. If the light comes back on great, if not then it probably is truly burnt out. If you decide to go in a replace it, do yourself a favor and just replace all of the bulbs at the same time. Or, look up Treeroot's ultimate LED thread for other options :)
Yeah I did some more searching after I posted this and found the "dash-smack repair" info. ;)
Thanks for the heads-up on Treeroot's thread. I'll see what I can find. I have no plans to mess with pulling the instrument panel apart just to replace a bulb - I can still tell what gear I'm in just fine by looking at the shifter. If I lose 2-3 more bulbs, I might consider it... Not sure my wife can figure out how to look at the shift lever.
