Gear shift and override question.
Azca
If there is a harder way - I will find it...
Surprise AZ.
Looks like I ran into a problem. Yesterday I attempted to shift from park into gear and it would not engage, had to use the override to get it home. Before I dive terribly deep into this I began to do a little homework using the FSM and wanted to understand all my options. I believe either the brake switch, or the ECU has died. Possibly the solenoid but, with so few working parts, that is kind of hard to believe. I did test the solenoid and it appears fine using an ohm meter but I need to apply voltage to it to verify (i didn't have a portable source or conductors handy to energize it safely).
As it appears that everything, with the possible exception of the brake switch, is unobtanium, does anyone have another suggestion? I may have to buy a used setup to make this go.
The brake switch easy to rule out, do your brake lights work when you press the pedal?
So which fuse was the culprit?
10 amp stop. Went into the garage, hit the brake pedal and nothing. Immediately noticed a warm glow emanating from the dash fuse compartment. 30 seconds later had a new fuse in there and working like a champ.
