Gear Reduction Starter
I didn't get that by reading the FAQ's either. I thought all you had to do was tie off the other wire because it was not necessary. Mine has an HEI distributor. Wonder if I need to wire it to the starter also?
Your HEI does not use a ballast resistor. It runs on straight +12V and therefore does not need the relay bypass.
Cooler is right, of course, but I did wire in a relay to my HEI. Just didn't seem right to splice the stock 16ga ignition wire to the 12ga HEI wire;)
Ed
