Gear ratio
sykesville,md
What is the formula for computing a final gear ratio?
ie: sm 420 1st gear 7.05:1
land cruiser 4 speed transfercase 1.99 low
4.11 ring/pinion.
now everyone will post the final ratio but how do you get to it.
thanks in advance, joe b
projektdotnet said:
I know this is a hijack but what is the 1st gear for the 4 spd (10/74) so I can figure out the stock crawl ratio.
stock first gear in any USA Land Cruiser tranny was garbage.....that is not crawling....
If you run tires larger than stock (I use 29" as a stock #), you're reducing your final ratio... multiply the final number by (29/your tire size) to get close to reality.
http://www.birfield.com/~ramullen/FAQ/TEXT/08-01.html
thanks everyone
