gear ratio
I think we have covered this in a thread somewhere in the past. With 35" tyres you will be happier with taller gears. 4.56 gears will get you back to "stock equivalent" (i.e. 4.10:1). With "stock equivalent" gears you will not need to adjust the speedometer/odometer.
Most of us would recommend 4.88:1 gears with 35" tyres, especially if you are at altitude. Any combination of larger/smaller tyres and gears that changes your effective ratio from stock will mean that your odometer and speedometer are not calibrated correctly. There are a number of ways to get this calibration corrected; transfer case speedo gear (Slee offroad), True-speed calibrator, Marks speedo calibrator, or Yellow Box speedo calibrator. All of these have been discussed in past threads. Let us know if you need assistance finding the information.
-B-
I assume you have a 97 fzj80. I typically would recommend 4.88 w/ 35s. You will turn slightly more rpm than with stock tires & stock gearing. This will help quite a bit. Ran a few myself this way for everything from daily commuting, to towing to offroading.
yeah i have 35"s and i was wondering what gears should i get and what should i do about my speedo?
