Gear problems? SOS
Palmdale, CA
(please read)I just bought a 1982 Toyota Land Cruiser and I love it! But i have big problems. The truck was sitting for three years without being started, brought it home filled it with gas and it turned right over and sounded great. I took it out on the highway and everything was running great. So then i wanted to see what this bad boy could do in the dirt, found this local place to go four bying in popped it into four low locked the hubs and it did amazing. Now when it was time to go home I unlocked the hubs popped it back into 2wd now heres the :censor: part as i start to drive off the gears are really short in fourth gear i red line at 40 miles an hour. Now I checked to make sure the 4wd was disingaged and it was the front drive shaft was spinning freely but for some reason its still geared like its in four wheel low and i have now idea what to do. Please help thank you for reading
You should post in the 60 series section. Your transfer case is still in low. Shift it into high. If the shifter doesn't work, get under the truck and do it manually.
IIRC, the 60 transfer case is vacuum-controlled. I think.
The linkage may be in the right position, but the transfer case is stuck in 4Low.
"IIRC" - If I Recall Correctly
Post up in the 60-series forum, they will be able to help you more than we can.
