Gear oil
dnp
Supporting Vendor
Jackson, MS
I hate it when I have to ask a question that's probably been asked 1,000 times, but after searching the FAQ's and performing other multiple searches, I can't seem to find the answer to: what gear oil do you folks recommend using in the front / rear differentials (Mine is a '95 with lockers)? The owner's manual says to use straight 90 weight in my climate (the deep south), and 75W-90 in the T-case. Whenever I change fluids, I usually try to replace them with synthetics; however, although I can find Mobil 1 75W-90 for the t-case, I have been unable to find straight 90wt in a synthetic.........I'm probably splitting hairs here, but I like to follow the original mfr's recommendations as closely as possible.......
Please let me know what you believe is acceptable for the front / rear diffs. Thanks for your recommendations.
I run the Mobile 1 Synthetic 75w/90 in both diff and the t-case. No issues. I just had my rear 3rd out this weekend and all of the gears and thrust washers looked awesome.
I use 75-90 Royal Purple, no problems:cheers:
