Gear Oil
30°54'01.53N / 84°04'56.04W
I know this has been discussed, but Im hoping to get some pointed responses from folks that live in the SE.
I live in the SE...what is the best gear oil weight for these conditions. Most of the parts stores sell 80W90 in gallon size jugs because its what they sell the most of...
I want to run non-synthetic first to flush the diff/TC. Once I flush with non-syn, will upgrade to syn...
Thanks in advance for your advise.:beer:
37 views and no one has an opinion?:crybaby:
I run Chevron Delo 80W90. I bought a five gallon bucket of it from a Chevron distributor here in Knoxville over 3 years ago. Still using it.
I use Mobil-1 syn in the t-case, but it's too expensive for the diffs.
If you do any water crossing, synthetic is probably a waste of money.
:beer:
Rookie2
Hey Knoxville...good to hear from ya. Im up there a bit for meetings at TVA.
Havent encountered any major water crossings as of yet (been a litte dry)...but that could change the first time I see a big puddle...
Followed by "hold my :beer: and watch this"!:grinpimp:
Hey TN_LC. I heard dat :D.
The Delo's a really good product. From what I gather, it's a step in between mineral and synthetic, almost like a blend. It's kind of hard to find. If you decide to go that route, it looks like there's a distributor in Chattanooga.. Parman Lubricants Company, 1-866-629-3888.
:beer:
Rookie2
I have used Mobil 1 75-90W synthetic for over 20 years in my LC's. I have used it in all gear boxes without any problems.
It always has come out when drained almost as good as it went in, except the front diff due to the chronic slight leaking of Moly grease that occurs. I recently started using a high grade of non-synthetic or synthetic blend (Valvoline) in the front diff due to heavy grease contamination (and changing it frequently) until I service my front axle and replace the axle seals. I do not do water crossing, so have never gotten water in any of my gear boxes; if you do submerge the axles, you probably should drain the gear boxes immediately afterwards; so no reason to use synthetic if you do that often.
The only change I have done recently is that due to a very slight amount of gear whine (which is probably normal anyways) I added some Mobil 1 80-90-140 (about 15%+/-) to the transfer and the rear diff to see if that would quiet it down; it seemed to. I also use the Lubegard Gear Oil supplement to all the boxes.
I recently drained all my boxes after 90,000 miles; the rear diff and transfer came out clean; about the color of very very weak tea, just a slight discoloration but still clear on your finger; not even close to the brown color of conventional gear oil when fresh. There was a 1/4 inch button or beard of metal filings/dust (no chips) on the rear diff magnet (and the front) and almost nothing at all on the transfer magnet; a few specks around the edges. The front diff however was contaminated with grease from the knuckles, so it was frothy as expected. The grease causes the gear oil to get too much air whipped into it; full of bubbles.
IMO the front diff is where you should focus your time and energy; drain and refill that a few times to flush it out, they all get some grease in them. Frothy gear oil (from getting grease in it) does not lubricate as well as pure gear oil.
I have driven my LC's all over the country, hot to cold, using the Mobil 1 75-90; you cannot get much better than Mobil 1 gear oil IME/IMO.
Summary: Mobil 1, 75-90W in all your gear boxes whether in the SE, NE,etc.
If I was doing a lot of continuous hauling of loaded trailers (not just towing a boat a couple of times a year) and frequent rock hopping, I would use the Mobil 1 80-90-140W. One possible disadvantage to using the heavier weight is maybe a slight decrease in fuel mileage and slightly more drag on the engine (slower acceleration). If in very cold weather, the heavier weight theoretically might make the locking and unlocking of the diffs a bit sluggish IMO.
Hope that helps.
Thanks Gray...Im going to rebuild my front axle tomorrow, so I will be draining, cleaning and refilling everything. Figured while Im under there, might as well baseline the rear diff and TC while Im at it.
Forgot to say; I frequently drive betweeen Florida, Georgia, Tennessee, Virginia, and up to the cold NE, at 70-80mph for hours at a time; no problems with the 75-90 Mobil 1.
If you already have grease in your front diff, and seeing that you are going to service the axle, you may consider this;
I added a quart of engine flush to my front diff with two quarts of gear oil, drove it 10 miles, and then drained it out; then drain and fill again, 10 miles, etc, to clean all the moly grease out; this helped clean out the diff without pulling the third member.
Either way, if you have grease in the diff/axle housing, it will take awhile to get it clean; suggest at least a few drain and fills of gear oil in the front before you add your final fill, whichever gear oil you go with. Ditto to your other gear boxes IF they are nasty looking; ie: like water got into them. IME; the transfer and rear diff stay clean.
Good luck, take pics, and come back with feedback on the front axle service.
The engine flush is a good idea. I will also be replacing my pinion seal, so I will have the diff open. Pinion seal is snotting black gobs of gube everything it gets warmed up. Plan to clean that out while its open as well.
Appears the PO didnt want to fix the pinion seal, so they tried using caulk or something to seal it up.:eek:
That's funny (trying to caulk it), wonder if the last time the axle was serviced someone forgot some seals? Hope you have all the parts (?CDan). Good luck.
That's funny (trying to caulk it), wonder if the last time the axle was serviced someone forgot some seals?.
Im guessing the servicing has never been done.
JT Differential & TPI4x4...ended up buying a Taiwanese kit from JT Differential (didnt know it was Taiwanese until I got it).
Bob (TPI4x4) is going to be bringing me a pinion seal and OEM inner axle seals to the garage so I make sure im sealed up nice and tight (he is coming down to the STLCA Work Weekend to make sure Im doing it right :grinpimp:).
Any name brand mineral 80w-90 or 75w-90 changed at more than 30k intervals will make the diffs last longer than you own the truck.
The Chevron Delogear Esi 80w-90 has been my favorite for years. It's gotten kind of pricy, though.
I agree that almost any name brand gear oil changed every few years will be just fine. I tend to change the diff oil after I've been in water over the axle, which is about once per year for all of the Cruisers, maybe twice for the 40.
The one problem with something expensive like Mobil1, is that you will hesitate to change it after a deep water session, and I'll take cheap gear oil with no water in it, over expensive synthetic gear oil with water, any day.
