Gear oil
Santa Cruz Mountains,CA. TLCA#7702
Hi All,
Just wanted to see what brands/type of gear oil people are using for there frt.&rear differentials w/factory lockers..My local parts store guy told me to buy sta-lube limited-slip
hypoid sae 80W90 api/gl-5* plus.I told him my 93 80 has lockers,he said 1-gal. would do it .Now I am looking at my haynes manual,front w/diff lock takes 2.8 qts,rear 3.4 qts.Now thats almost a gal.for the rear,so I will need to pick up another gal. for the front.This stuff is not cheap at $24.99 a gal.or do people buy 5-gal.or pints?
Thanks,John
I buy gear lube in 5 gallon buckets. The "Coastal" brand at AutoZone meets every spec needed and costs about $25 for 5 gallons. Get a bucket pump and you are all set.
I bought 2 gals to do my front/rear ends and xfer case, actually, i had to add about another pint or so from another can that i had. it seemed like it took a bit more than the specs called for (yes, the truck was level)
not an expert on the different oils but I don't think you need the oil with limited slip additives because the lockers are not clutch based which would require additives that sta-lube has. I just used valvoline to hold me over till I do a full rebuild on front/rear and then will be switching to synthecs.
Buy Lucas gear oil...........it the only way to go!:cheers:
Buddy spilt a transcase & didn't know it:crybaby: , ran it most of the afternoon, then discovered it & it still drove home:eek:
Its in all our rigs:bounce: .
What weight and type of Lucas Gear Oil (Synth or Heavy Duty) do you run in the front, rear & center diffs?
Riley
Mobil 1 75w 90.
Buck
Lucas is garbage. Use a name brand gear oil and call it a day.
http://bobistheoilguy.com/images/lucas/lucas.htm
Thanks for the link. Pretty obvious Lucas creates aeration. I did not know that.
The local Costco sells gear oil in 5 gallon buckets (not sure of the price for the Mobil 1) and Harbor Freight has an oil pump for $10.00. I will just look for 75w90 or 80w90.
Thanks again,
Riley
My limited understanding is that the diffs don't see the high temperatures that make synthetics very attractive. I've been putting plain ol' 80w90 Coastal in mine. I figure that if I haven't pumped $$$ into the diffs, I'm more likely to change the fluids after any kind of major water crossing/submersion.
Hayes
Hayes
X2.
If you spend the big $$ on gear oil, you will be reluctant to change it after a dunking. I use good (non-synthetic) gear oil in my 80 and Coastal in everything else.
That really is a smart way to approach gear oil.
Buck
That really is a good approach to gear oil. But don't discount lucas because of "bob's" little toy gearbox. He is testing the additives, not the oils themselves anyway. Any good oil should not need any additives. But thier gear oils work really well for me and some people I know. I had many leaks on another truck that dissapeared after switching to lucas gear oil. Never any breakdowns either, but of course I never disasembled to check for wear. I personally don't believe in additives to fix problems, but Lucas gear lube seems to be a quality product used quite extensively.
Not true. The additives are part of the chemistry of any oil, whether designed for gears or a running motor. Pure mineral oil would cause near immediate failure of the component it was lubricating. In the case of ring and pinion gears, the pressures at the tooth contact spot are extremely high. The additives allow this to happen without undue wear.
You may be confusing additives, with aftermarket add-on bottles of mystery fluid, that I agree, have no roll to play here.
Any GL5 spec lube in the right viscosity range will provide adequate lube for our Land Cruiser differentials.
I think I will get the coastal 5-gal.&take the other stuff back.I have had lots of dunking&have not changed fluids for a long time.From salt water at pismo to river crossings on deer valley trail.This is heading for a major tune up!I had one done 5-6 yrs.ago at 96K.well lots of oil changes&some other stuff done.The 93 80 now has 170K,so I figure a 60K tune up should be done along w/hoses&belts.These trucks love abuse,it runs great!!
Thanks AJP we should do the waterfall hike at rubithon again,love that water!
John
Well, yeah. That's what I meant. Any production "lube" for a particular pupose like mobil, pennzoil etc are already formulated with whatever additives they need to perform and no additional things should be required.
2Xs that . . . . .:flipoff2:
John, the sooner you understand something about 80 ownership the better. Most of what people on the other side of counters will tell you about them is bull****. This is/was a limited production vehicle that shared almost no parts with any other vehicle on the planet. Just on this one item, he's steered you to the wrong fluid (ltd slip fluid has friction modifiers in it) and the wrong quantity. Get yourself a factory manual and life will be good.
DougM
DougM
Couldn't have said it better!
That test is bull****. First of all for it to be vaugely scientific he should compare the same oil with and without lucas. Plus how fast is he running those little gears? The oil pump is drawing oil from the pickup and is running immersed in oil. It wont foam up like that because its not a gear half submerged in oil, its just pulling it along. Its possible you could achieve that aeration with a rearend, but again its not a tiny volume of oil being whipped at high speed by a tiny gear, its a big ass gearset turning in a decently sized volume of oil.
