Gear lash? Normal?
Normal?
  • Yes, Send it!
    Votes: 0 0.0%
  • No, Rebuild it!
    Votes: 0 0.0%
  • Total voters
Tremont IL
Website
www.toyota-pekin.com
1990 Toyota FJ62. Factory 4 Speed Automatic.
So... Here is the question. Customer is stating he does not like this little bit of a tick/clunk noise when going into gear... Especially from reverse to drive. This is the only automatic we have seen in a 40/60 in years. None of can say conclusively that its not "normal"
I am really scared that dismantling this and rebuilding it will result in no difference. Thus a giant time suck.
Thoughts? Advice? Memes?
Thanks!
Eric in Pekin
Yeah.. I'm sure others will chime in here, but if you do a little bit of searching on mud you'll find a ton of info on this issue.
It all depends on how bad it is and what the customer wants/uses it for. If it's really bad it could be something that at a certain point completely fails/strips and then you're in pretty big trouble if traveling remote.
You can mitigate wear quite a bit by doing what I described above.
All depends on priorities and budget right.
If I'm idling high because of my AC being on or something, going between D & R can cause a pretty severe jolt in mine.
It's universal and due to wear on the the output shaft/input gear splines.
"They all do it"
Fix is as above. If I still had the autobox, I would have done the McNamara gear as prophylaxis.
