Hey All,
Well, I took delivery of my new truck (well, 27 years old). As expected there were some problems that I need to be tracked down.
One of them has to do with the guages. When I test drove it the first time, I noticed the oil pressure gauge wasn't working. When I asked about it, he just shrugged his shoulder. HOwever, when looking over the truck, I noticed there was no wire going to the sending unit.
After taking delivery, I traced down on this wonderful site a copy of the wiring diagram for an FJ40, and was able to find the proper wire hooked up to a ground in the engine compartment. After re-connecting to the oil pressure sending unit the oil pressure works fine.
This morning, when I was leaving to run some errands, I noticed the gas gauge was not working. (I think the temp was also not working, but couldn't verify as the engine was cold.). I drove to the gas station and filled the tank, and now the oil pressure is not working, along with the temp, gas, emergency brake indicator light, nor back-up lights.
First thing I did was search on this site for similar problems, but didn't find any.
I checked fuses, pulled the fuse block, and I'm getting 12v to the gauge circuit at the back of the block, (checking on the wire itself, not at the fuse).
I pulled the wire from both the oil pressure and temp, no voltage.
It would appear that I have an open somewhere after the fuse block, before it splits to the guage cluster, emergency brake light on the dash, and the back-up lights, since according the wiring diagram they all feed off the same circuit.
Any ideas where to look? Anybody else had anything similar?
Baffled in Costa Rica
