Gas Tank
Lots of options:
1. Place bucket under the drain plug.
2. Remove the drain plug.
(I'm guessing you didn't realize there was a drain plug?)
or
Drive around till it's closer to empty
or
Buck up and just lift it out. 4 gallons only weighs about 30 pounds.
The in-tank fuel pump on my wife's Suburban died a few months ago. Fawker still had 30+ gallons of gas in it (42 gallon tank) and I had to drop the tank...
Thanks E rock, yea I know about the drain plug but dont have anything that can collect 4-6 gallons is all. I would just pick it up but I figured if I disconnect the fuel line on the side it will start pouring out of the side.
you can get 5 gallon buckets pretty cheap at a paint store.
Ive got a 76' and had to pull the tank before restoration of the tub. My problem was the same, didnt have a 5gal bucket. I took a 2.5 gallon gas can and a pair of large vicegrips and slid under the cruiser, clamped the end of the hose next to where the rubber line ties into the hard line at the frame and disconnected it. Theres enough slack from the hose to get the end of it to the can. I emptied the full gas can into my daily driver, wich happen to have only a quarter tank in it at the time.
Get a six pack it takes a while, but you get a good buzz!
