Gas Tank Vent Question
San Antonio TX
OK, I finally had to fuel up the 40 after having the tank sealed, painted and reinstalled, After fueling up I smelled fuel which is nothing unusual in a 40 but more than the usual so I pulled over, looked around and there is fuel all over the floor. AFter checking around I realized I left the vent hose off the side of the tank so I just need to know where it goes? I think the PO just dumped it out the hole in the middle of the floor.
Thanks
what year is your rig:confused: is your cap vented,is there a black ugly box of sorts with places to hook up hoses to:confused: if you will look there is a shield on the passenger side, right behind the passenger side seat is this box of sorts:D thats where it is suppose to go.if its not there get a vented gas cap and plug the end off the hose.problem solved.make dam sure nothing is leaking around the tank.and the filler hose also:beer:
there is also on some for than one spot on the filler neck to put on hoses.i think one might be a simple overflow.but dont hold me to that.im sure somebody will post a picture.if im right there was a tee coming off the filler going to the tank
It's a 73 model and all of those hoses are connected. This is a little neck? on the drivers side and that is what is missing the hose. any ideas?
drivers side:confused: you should have nothing on the drivers side in reference to gas.yes my last 40 was a 73 so just plug it off unless like i said it goes to the filler neck.on mine i tossed the box behind the shield in the trash.:D
If it is half way up the tank on the drivers side it may be the carb return line. At least it is on the 76. The line came up through the floor between the seats.
