gas tank line?
I see the bottom of the gas tank on my 69 has a threaded hole and a bolt in it. I also notice that the threaded hole as 2 holes in the threads (gas to flow through). My question is, what do i need to get a line run out of this hole to my fuel pump?
The hole in the bottom is a drain not for your fuel line. The fuel line attaches to the thread hole in the side of the tank opposite the filler neck. I do have a tank that came in a parts vehicle that had a hole drilled in the drain plug and a barbed fitting soldered in it for a fuel line.
John
Right, and you don't want what may be in the bottom of the tank. The fuel pickup is above the bottom of the tank to allow sediment and water to collect.
Ed
