I'm putting a steel tank in my 75 FJ40 with a V8 conversion and edelbrock 1406. Pulling the plastic PO put in. This truck has all the emissions stripped and now I'm starting over. The hook up's on the new tank are fairly easy to understand... three on top together go to the vapor box, out of the vapor box to the new charcoal canister I got from the junk yard, charcoal canister out to the carb intake. 1st question... attach the charcoal out to the aircleaner, or below the carb to the carb vacuum port? 2nd question... the driverside of the tank has a port I think is the carb bowl overflow in to the tank? Does this need to be hooked up? Where if so? I don't see anything on the carb for a bowl overflow.
This has an electric fuel pump that is simply hard wired to be on when the engine is on.
