gas gauge broke - where to start?
Philadelphia, PA
Just got my 1980 FJ-40, so Im taking care of all the little stuff I need to fix. My gas gauge to broke. As far as I know its not the fuse, because the other gauges work. Am I wrong about this? where should I start looking for the problem?
thanks
Ohm out the sending unit, and the signal wire to the back of the insturment cluster.
Good luck!
-Steve
Remove the ground wire from the top of the sending unit and clean it up a bit. I've had corrosion there that could cause your problem.
