Gas Door Cable??
Calgary Alberta Canada
Fuel Door Cable??
Hey Guys!! It's not working! I pull the lever inside the 80 and it does not pop the fuel door.... I have to pull it manualy from the inside of the the cab.. let me know if you know how to tighten the cable.. I can't figure it out.. thanks guys... later..
Mine broke also but im not payin to get it fixed. My actual cable broke so right now, I just push it closed and hope it stays.
There is supposed to be a little spring on the door. It often falls off and gets left behind. Check to see if yours is there. To open the fuel door in the meantime is a two person job. One pulls gently on the release in the cab, the other opens the now unlocked fuel door. Call Cruiserdan and he should be able to get you one.
I have devised a redneck replacement that has so far proved more durable than the little metal spring thingy and less likely to fall off at random. I can put some pictures up if anyone is interested. It involves a 4 tooth section from a 1991 Ford Escort timing belt with on tooth shaved off, one tooth with top and bottom 1/3 removed and the remaining 1/3 of the tooth shaved off. Makes a little rubber spring.
The spare timing belt outlived the car. It has made good project stock.
i had to replace that spring on my 4runner a few weeks ago , its the same spring on the cruiser, so i got 2 ofem to do a preventive type maintenence on the cruiser as well.
my door pops fine... it just doesn't release via the cable... i have to push the lever from inside the back of the cab,.... i guess i am wondering if you can adjust the cable,.,. thanks,
