This is related to my fuel tank pressure thread....
https://forum.ih8mud.com/80-series-tech/311304-happened-me-gas-venting-issue.html
But I started a seperate thread to get a wider audience. In regards to the 80 gas cap, what is the normal position of the vacuum valve inside the gas cap.
In other words, the white valve when you pull off the cap and look inside. Does it normally rest against the four stops under spring pressure and can you push in the valve manually with your finger or not?
I wish I had another one to compare.....
