fzj80 with 35"s
okay i have 35"s and im running stck suspension, i really need a lift kit cause its pretty rediculous right now, should i go 4" or 6". and where should i get it from. sleeoffroad, sky jacker etc.....
Searching on here will help a lot. There is ton of info on all the lifts and height.
To help you out you will only need a 4 inch lift to easily clear those and either slee or ARB OME are the best options.
X2 on a search or the Faq, there is a ton of info on this.
I am curious as to how much tire rub/bump you get around town with stock suspension and 35's.
